I have the following channel setup:
routes:
/math/:
controller: channel
filter: tag:[linear-algebra,statistics,probability,calculus]
And I use a custom math.hbs file to load the channel content. But I’m wondering how I can modify the meta properties?
{{!< default}}
<header class="site-archive-header">
{{> site-header}}
{{> header-background background=feature_image}} {{!--Special header-image.hbs partial to generate the background image--}}
<div class="inner site-header-content">
<h1 class="site-title">Math For Machine Learning</h1>
<h2 class="site-description">
This is all the available math you need for Machine Learning. In this section, you will learn Linear Algebra, Statistics, Probability Theory and Calculus.
</h2>
</div>
</div>
</header>
{{!-- The main content area --}}
<main id="site-main" class="site-main outer">
<div class="inner posts">
<div class="post-feed">
{{#foreach posts visibility="all"}}
{{> "post-card"}}
{{/foreach}}
</div>
</div>
</main>
I’m specifically looking to modify the meta property og:title and og:description, for SEO purposes. How is this possible, given the current handlebars file? I want to avoid a Javascript solution, as I would like the meta properties to be static, or at least server-generated like for the tags.
