Hi everyone,
I’m getting the below error:
The reason is because I’m running a reverse proxy (using Cloudflare workers) to proxy all traffic
to : wowclub.com/blog/*
And it works well for the most part. It is fully usable. But these are the other things that aren’t working:
Search
Appending a /edit to the end of a blog post to edit it
I think it has something to do with the content API
Would really appreciate some help to point me in the right direction.
Thank you!
@vikaspotluri123 Would you know?
I read your reply here , and I’m not sure if I need to change anything in my Nginx configuration.
After all, I have set up cloudflare to do all the re-directing.
thanks!
If you’re running the admin panel on a different domain, try setting the admin url (search for admin on this page):
https://ghost.org/faq/change-configured-site-url/
Hi @vikaspotluri123 ,
I suppose that does apply to me. I’m technically running the admin panel on Ghost Admin
So I ran the command ghost config admin.url https:// blog.wowclub.com/blog
But, unfortunately I’m now in a 502 error that I can’t resolve.
502 Bad Gateway
nginx/1.10.3 (Ubuntu)
I’ve tried to re-setup nginx, restart ghost - to no avail.
ghost log -f shows that ghost is running fine on production & no error.
Bit stumped. Anything I could try?
Is there a way to revert my changes?
I don’t think it’s possible to remove a config key. You’ll have to manually edit the config file and remove the
"admin": {
"url": ""
section
The bad gateway error makes me think something is messed up in the DNS / IP level in terms of how you configured your domain / proxy
As soon as I removed that config key, it started to work again
Thanks!
Though, I’m still where i was w.r.t to the original problem - but at least things are back up and running!
did you add any custom headers to the blog response?
I haven’t added any custom headers.
But, we do use Cloudflare workers to proxy traffic - so I don’t know if that is adding something to the response.
I have a feeling this might be a limitation of the default nginx configuration. If you set up SSL, it adds this line by default:
The workaround is to comment that line out, or add logic to send the allow header if you’re on the Admin origin
Thanks!
I’ll check that out, but when I’ve I understand nginx better.
I’m bit worried I’ll break things again
themeix
October 20, 2022, 6:03am
11
add_header X-Frame-Options "allow-from https://newwebsiteurl.com/";
Sometime we may need to give x-frame access to a specific domain… above code may help for that.
