I am trying to configure ghost on AlmaLinux but keep getting an error
OS: AlmaLinux, v9.1
Node Version: v16.19.0
Ghost-CLI Version: 1.24.0
Environment: production
Command: 'ghost install --db=mysql'
warning ghost@5.26.4: The engine "cli" appears to be invalid.
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.29.1"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.29.1"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.27.0"
warning Resolution field "moment-timezone@0.5.23" is incompatible with requested version "moment-timezone@^0.5.31"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.29.4"
warning Resolution field "moment-timezone@0.5.23" is incompatible with requested version "moment-timezone@0.5.34"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.29.3"
warning Resolution field "moment-timezone@0.5.23" is incompatible with requested version "moment-timezone@^0.5.33"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.27.0"
warning Resolution field "@tryghost/logging@2.3.5" is incompatible with requested version "@tryghost/logging@2.2.3"
error An unexpected error occurred: "https://codeload.github.com/TryGhost/mock-knex/tar.gz/8ecb8c227bf463c991c3d820d33f59efc3ab9682: getaddrinfo ENOT>
yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
info There appears to be trouble with your network connection. Retrying...
info If you think this is a bug, please open a bug report with the information provided in "/var/www/millcityeats/versions/5.26.4/yarn-error.log".
info Visit yarnpkg.com/en/docs/cli/install for documentation about this command.
Exit code: 1
--------------- stdout ---------------
--------------- stderr ---------------
error An unexpected error occurred: "TryGhost/mock-knex/tar.gz/8ecb8c227bf463c991c3d820d33f59efc3ab9682: getaddrinfo ENOT>
