If you’re looking for some help, it’s important to provide as much context as possible so that people can assist you. Try to always mention:
What’s your URL? : https://www.propftx.com/blogs/ghost/
What version of Ghost are you using : 5.79.1
What configuration :
Enter your blog URL: (https://www.propftx.com/blogs)
Enter your MySQL hostname: (localhost)
Enter your MySQL username: (ghost-542)
Enter your Ghost database name: (propFTX_prod)
What browser : Chrome
What errors or information do you see in the console : Failed to load resource: the server responded with a status of 404 ()
What steps could someone else take to reproduce the issue you’re having? Use the below IP address to find the error :http://13.200.51.241:2368/ghost
Looks like you’re trying to do a subdirectory setup. Please post your config.production.json and the config file for whatever you’re using to proxy. (Nginx?) Be sure to remove any passwords and secrets first.
