I run ghost by NODE_ENV=production node current/index.js
, and then got the error:
ghost@d46d6f30f9f7:~/Ghost$ NODE_ENV=production node current/index.js
[2023-08-15 08:50:19] ERROR Unable to run migrations
"You must be on the latest v3.x to update across major versions - https://ghost.org/docs/update/"
"Run 'ghost update v3' to get the latest v3.x version, then run 'ghost update' to get to the latest."
I read other posts saying that mysql
needs to be upgraded to 8.0 to solve this problem, but my mysql
version is already 8.0.
How to Reproduce:
- version of ghost-cli: 1.19.3
- version of ghost: 5.59.0
- node-v16.14.2 is used when installing ghost-cli and after that I removed node16 and used node-18.14.2.
- command:
Is it that ghost v5.59.0 does not support node18?
