I have a self-hosted blog
I want to build a custom home in Framer, so I can update easily with marketing stuff and other details.
I still want to keep blog in Ghost as is without messing up my settings.
Is it possible?
Home (Framer): mywebsite .com
Blog+Newsletter (Ghost): mywebsite .com/blog
You need to go to config.production.json or config.development.json (depending on the environment) to set the desired url - for example http://localhost:2368/blog/
config is located on the path ghost/core/you config
If you are self-hosted, I assume you have already configured nginx. You will need to reconfigure the nginx configuration for proxying to http://localhost:2368/blog/
After that, Ghost will be available on the url /blog/
Most likely, publications posted at the old url will be unavailable, and all redirects will need to be manually configured in nginx (using regexp(?))
OR
Without change config json
You can set up location for /blog in nginx on proxy_pass localhost:2368 (port using Ghost cms).
But you need to proxy the entire url to Ghost, without /blog/. So that Ghost cms can process the request correctly
WOW! Thank you for the detailed reply! GREATLY APPRECUATED!
sounds complex btw. I need to google mostof what you suggested. I used DigitalOcean Droplet that did the ghost set up.
My main confusion came in DNS. If I set up my root URL for framer, that would influence rest of the URLs such as myweb .com/blog how would I have 2 DNS directing 2 different places under 1 name?
If yes, when you change the dns settings to framer, the domain will stop looking at the server from ghost
You need 1 proxy server, dns domain settings should look at it. The proxy server should distribute requests to either framer or digitalocean, depending on the url
Unfortunately, I am not sufficiently familiar with framer and digitalocean
