Hi all,
I need some clarity:
Between my setup experience, and the support desk at PikaPods.com, together we figured-out that both the Login email address, and the From address had to be postmaster@mg.yourdomain.com. Because sending failed until we set them both the same. Plus, the from addres is not being used, instead bulk email comes from noreply@mg.yourdomain.com. What’s actually supposed to be happening with that whole from address thing?
Thanks,
Lance
How was your experience using ghost on pikapods :)
I was new to both Ghost & PikaPods, so everything took me a little longer as a newbie; that’s going to be the case anywhere the first time through. PikaPods is incredibly easy! Fill-out the config questions for whatever you’re starting, and click the start button; 5 seconds later, all the server requirements plus your app has been installed, and you are ready to sign-in as the admin.
For Ghost, the PikaPods setup page asks all the transactional email questions, like SMTP, email address, etc. Then Ghost asks for your mailgun API info.
