What’s your URL? https://dudethatserin.com
What version of Ghost are you using? v5.49.0, just upgraded before opening this and I’m still having the issue.
How was Ghost installed and configured? via my Hostinger VPS.
What Node version, database, OS & browser are you using? Node: v16.20.0 Windows 11 (latest version), Brave v1.51.114
Well, this is a two fold question for me.
I tried visiting the URL in the browser and this is the error I got:
{"errors":[{"message":"Resource not found","context":null,"type":"NotFoundError","details":null,"property":null,"help":null,"code":null,"id":"48406a90-f66e-11ed-a71c-8f22bd906a63","ghostErrorCode":null}]}
I am attempting to make an Obsidian plugin and the API is failing when I test it and this is what shows in that console (not helpful which is why I shared the above)
caught (in promise) Error: Request failed, status 404
at new t (app.js:1:1668159)
at tU (app.js:1:1668351)
at app.js:1:1669028
at app.js:1:235927
at Object.next (app.js:1:236032)
at a (app.js:1:234750)
- What steps could someone else take to reproduce the issue you’re having? Simply visit https://dudethatserin.com/ghost/api/v5/admin/posts/?formats=html,mobiledoc in the browser and the error appears.
This is the code I’m using to test the API…
const token = sign({}, Buffer.from(secret, "hex"), {
keyid: id,
algorithm: "HS256",
expiresIn: "5m",
audience: `/${version}/admin/`,
console.log('token ', token);
const apiTest = await request({
url: `${settings.url}/ghost/api/${version}/admin/posts/?formats=html,mobiledoc`,
method: "GET",
contentType: "application/json",
headers: {
"Access-Control-Allow-Methods": "GET",
"Content-Type": "application/json;charset=utf-8",
Authorization: `Ghost ${token}`,
console.log(apiTest);
The token loads fine and displays in the console but the apiTest does not. So, I know there is something there.
This is how my variables are defined (from above)
settings.url = https://dudethatserin.com
version = v5
base_url = /ghost
const key = settings.adminToken;
settings.adminToken = the long code with a colon separator (:) from creating an integration in my admin panel
const [id, secret] = key.split(":");
I don’t see any issues. Am I missing something?
EDIT/Update: I’m also trying to switch from using the Buffer.from... part of my code as I want/need this to work (whole point of me coding this as it doesn’t work already) on iOS.
Someone pointed me in the direction of jsrsasign - npm
Though that seems to be for websites only. I attempted to get it working via my code but ended up with the following image:
Then when I ran that npm code I got the following:
npm i --save-dev @types/jsrsasign-util
npm ERR! code E404
npm ERR! 404 Not Found - GET https://registry.npmjs.org/@types%2fjsrsasign-util - Not found
npm ERR! 404
npm ERR! 404 Note that you can also install from a
npm ERR! 404 tarball, folder, http url, or git url.
npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\dudet\AppData\Local\npm-cache\_logs\2023-05-19T17_47_26_347Z-debug-0.log
So, it doesn’t work. I just need a way to create the token in such a way that it works for the API and doesn’t need Node.js at all. I want people to be able to install and setup this plugin on their iPads or iPhones or Androids and not need to clone and run my repo.
Other plugins have this possibility but looking at their code, it appears they don’t have a strange hex token or whatever Ghost needs. So it seems very difficult if not impossible.
