Hello,
I was wondering if it is possible (and if it makes sense) to run one instance of Ghost as a headless CMS for two websites in the same web server?
If that is not possible (or not advisable) and I have to install and run two separate instances, should I have a server with the double of the recommended memory (2x1024 Mb)?
Many thanks
If you’re using Ghost as a headless CMS, traffic to the instance should be relatively low (since it’s just your content editors and build bots accessing it), so you’re probably don’t need to upgrade to a higher tier hosting config. That said, if you do run into issues, most of the VPS hosting providers I know allow you to increase instance size if needed
Thanks @vikaspotluri123, that makes sense.
