Ghost <> BlueSky integration - how to use my already existing BSky username?
Hey folks,
So I’m trying out the BlueSky integration with fed.brid.gy and noticed it creates a new handle instead of using my actual BlueSky account.
I’ve already got followers on my real BlueSky handle and don’t really want to start from scratch with a bridged account. Is there a way to connect my existing handle instead? Or is this just how bridgy works?
If anyone’s figured out a workaround I’m all ears. Otherwise I guess I’ll just have to stick with manual cross-posting for now.
Cheers
I don’t know about the bridge thing but you can easilt automate your posts using integration with Buffer, Zapier, n8n etc.
I think the bridge is supposed to import replies on BlueSky as comments on your post though?
Were you able to figure out a solution for this? I’m in the same boat here.
