Hi, I am trying to make a blog using Ghost as a headless CMS(self-hosted), Svelte as my frontend and Expressjs for the backend. What I don’t understand is that to get content from Ghost I have to host the ghost server and then host the express server, and get content from Ghost through the content api. But I don’t want two servers, I only want one. My end goal is to have a Svelte frontend with content from Ghost.
Hi @DavidDarnes, I have the express server so I can see my frontend. I don’t know how to connect my frontend to the ghost server. When I go into the ghost server(localhost:2368) I don’t see my frontend, I see the ghost default site. Also, I don’t know what Netlify is or what is used for. How does that work, how can I host the frontend and then get content from Ghost? Would I have to have Ghost open in my computer all the time?
Sounds like you need to do some more investigation into frameworks that can use Ghost as a headless CMS. A lot of Static Site Generators (SSGs) don’t need to be ran within an Express server and can be run on their own via a command. Take a look at some of these and their linked documentation:
- Eleventy: https://www.11ty.dev/
- Gatsby: https://www.gatsbyjs.org/
- Gridsome: https://gridsome.org/
- Next.js: https://nextjs.org/
Netlify is a hosting platform where all of the above SSGs can be deployed and hosted. In order to use these SSGs on a live domain they’ll need to source the content from a Ghost installation. You’d need a production version of Ghost running, either by running it on a hosting platform like Digital Ocean, or on Ghost(Pro) rather than running it locally like you have at localhost:2368.
Hope that makes sense ![]()
