With Ghost 5, you used to be able to set the category where your site would appear in Ghost Explore. Now that feature seems to be have been removed and sites are categorized in some black box automatically. My site’s category was changed from Science (which I chose) to Personal which is less appropriate. There doesn’t seem to be any way to change it. Is there a way to change your site’s Ghost Explore category? Thanks.
we switched to managed categorisation for now because manual categorisation was getting abused a bit – but I forgot to sync the old categories over! just done that now - so you should have your old category back
if not, let me know your site URL and I’ll update it manually for you
Confirmed the category reverted to what it was. Thank you.
