Hi – I’m sure this is simple but I can’t seem to find a way for the GoDaddy DNS settings to include mydomain.com alongside www.mydomain.com in redirecting to my Ghost site. Is there an easy fix? Thanks for the help!
S.
S.
You should point both of them at your server and then use the following method to configure both with Ghost CLI:
It is on their control panel. You should be able to find it.
