Hi everyone,
I am a recent convert from Wordpress. Ghost works fine on my local. I have a “successful” install to my staging site, but am running into some interesting behavior. Here’s some context behind it:
4.x (latest, fresh install from last night)
What configuration?
- I’m running Debian 9 with DirectAdmin handling the nginx stuff. (Nonstandard stack, yes.)
- I wrote my own server block for ghost in the conf file per DirectAdmin’s way of handling nginx, using vhosts
- It works: the site loads. (Hope this is useful for anyone who wants Ghost to get along with DirectAdmin) - I can also upload json data from my local into staging for migration.
- But it looks like I can’t put/delete anything!
- When I try to delete the default ghost user, it says “This user could not be deleted.” When I try to edit a post, “server was unreachable.” I don’t see a response on my Network tab, from any of my put / delete requests.
I have tried:
- checking the sizes of php-fpm and nginx. They are quite large (more than 10MB) and I’m not migrating anything; in fact, my migration went alright – the posts entered the database.
- I am ruling out “permissions” as the ghost-cli will have corrected me pre-install to set files to the correct octal value.
- What I am asking is, could this be due to nginx server block configuration? I followed the “base” config" and the site loads, so I assume some of my routing was correct.
Here’s what I based my nginx block off of:
server {
listen 0.0.0.0:80;
server_name *your-domain-name*;
access_log /var/log/nginx/*your-domain-name*.log;
location / {
proxy_set_header HOST $http_host;
proxy_set_header X-NginX-Proxy true;
proxy_redirect off;
Directadmin uses vhosts (virtual hosts) to handle nginx configurations. When I installed ghost, I skipped the nginx configuration knowing that I could just "point" nginx to the correct folder. Perhaps there's a config somewhere I missed out? Any advice would be greatly appreciated, and I notice that Directadmin installs with Ghost are rare. I think this is useful for others down the line.
Thanks in advance for checking my thread :)
