Hello, not sure if this is the correct place to mention this or if I should report here Issues · TryGhost/migrate · GitHub
I am happy to help with working out a PR for this when I get the chance.
- What’s your URL? This is done on the command line when migrating from Ghost 3 for use with v4
- What version of Ghost are you using? Ghost migrate CLI v0.16.5
- What configuration? used with macOS v11.1
- What browser? n/a
- What errors or information do you see in the console? none
- remove extra HTML added to markdown card - to fix open json file and remove
<html><head></head><body>and then remove</body></html> - fix blockquote - open json file and and change
>to>character.
