Hi all. I have fresh install ghost using bitnami in gcp. At this time, member portal setting wonderfully. But, when i after setup domain and ssl, member portal is not working. I can enable it from the admin menu but the customization page show white blank page. Anyone has the same problem with me? How could you solve that? Thanks
Hey @Kanda_Fajar ![]()
Can you share the output of your console? If you’re not sure how, here’s a guide to opening your browser console
It looks like your URL is set as http://... instead of https://... which is creating issues.
You’ll need to update the url and restart ghost:
ghost config set url https://delomite.com
ghost restart
i am deploying behind a reverse proxy.
atm there are issues setting up ghost with https for i get an EADDRINUSE error.
am i excluded from using portal?
