Hey guys, I keep having a problem with Ghost immediately shutting down after installation. The error is very vague, any ideas as to what might be the problem?
- What’s your URL? localhost
- What version of Ghost are you using? 5.34.1
How was Ghost installed and configured? This is a fresh
ghost install local. Even ghost-cli and Node were reinstalled. - What Node version, database, OS & browser are you using? Node 18.14.1, SQLite, Windows 11, Google Chrome
1) GhostError
Message: Ghost process exited with code: 0
OS: Microsoft Windows 11 Home, v10.0.22621
Node Version: v18.14.1
Ghost Version: 5.34.1
Ghost-CLI Version: 1.24.0
Environment: development
Command: 'ghost install local'
Stack: Error: Ghost process exited with code: 0
at ChildProcess.<anonymous> (C:\Users\samvn\AppData\Roaming\npm\node_modules\ghost-cli\lib\utils\local-process.js:68:24)
at ChildProcess.emit (node:events:513:28)
at ChildProcess._handle.onexit (node:internal/child_process:291:12)
- Install Ghost using
ghost install local. This process fails when the install script tries to launch the Ghost instance. - Remove Node 16, install Node 18.
- Retry installing Ghost using
ghost install local. This process again fails when the install script tries to launch the Ghost instance.
