Message: Ghost process exited with code: 0
Hello darkness, my old friend:
    OS: Microsoft Windows, v10.0.17134
    Node Version: v8.11.3
    **Ghost-CLI Version: 1.9.6**
    Environment: development
    Command: 'ghost start'
How would I even begin to fix this?
This happened during updating ghost to latest version, from version 2.x? when there was not enough space to continue.
C:\webdev\ghost>ghost version
Ghost-CLI version: 1.9.6
Ghost version: 2.2.2 (at C:\webdev\ghost)
C:\webdev\ghost>ghost doctor
Found a development config but not a production config, running in development mode instead
√ Checking system Node.js version
√ Checking current folder permissions
√ Validating config
√ Checking memory availability
from above looks like it updated to last version but something is still wrong since ghost won’t connect.
If you want someone to help you then you’ll need to provide a lot more context and information than that. Every new topic comes with a template including suggested debug information - but you’ve ignored / deleted all of it
what more info do you need?
I’ve put debug info and reason of how it happened all in the first post.
this is in localhost so I obviously can’t share webpage.
I’ve fixed this in the end by creating brand new installation of ghost in another folder,
and replacing new database file with the one I had from previous installation.
so, not really fixed, but managed.
