- What’s your URL? https://fivemincodes.com/
- **What version of Ghost are you using?
Ghost-CLI version: 1.23.1
Ghost version: 5.22.9
And
- How was Ghost installed and configured?
I am using the Linode server to configure the Ghost.
I followed all the steps in the documentation and please see below for more information.
- Added NS records to the domain
- Added A records with the server’s IP
- Successfully run the
ghost installcommand andghost setup sslcommand.
- What Node version, database, OS & browser are you using?
Node version - v16.18.1
database - MySql
OS - Ubuntu 22.04.1 LTS
browser - Chrome
No errors were found.
I tried with my domain to load the site but it’s not working.
When I tried using the server IP, It will load a welcome message of Nginx.
Here are my Nginx Configurations,
- fivemincodes.com.conf
server {
listen 80;
listen [::]:80;
server_name fivemincodes.com;
root /var/www/fivemincodes/system/nginx-root; # Used for acme.sh SSL verification (https://acme.sh)
location / {
location ~ /.well-known {
allow all;
client_max_body_size 50m;
- fivemincodes.com-ssl.conf
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /etc/letsencrypt/fivemincodes.com/fullchain.cer;
ssl_certificate_key /etc/letsencrypt/fivemincodes.com/fivemincodes.com.key;
location / {
allow all;
client_max_body_size 1g;
