3.17.1 -
What configuration?
8GB Ram, 4CPU server running with 0 traffic and 0 usage
Ghost blog with 1000 posts, 2 authors and 15000 tags -
What browser?
All
The Ghost posts API is still fine and loads quick (even though sometimes 2-4 seconds), but the tags API takes like 40-60 seconds (much more likely as nginx times it out by then).
Why is it so ? I am kind of bummed by this as I always thought the API and query is like wordpress/normal database query where your only limit is your resources, but here my server is never going above 10% of resource usage and TAGS API taking 60 seconds with just 15000 tags ? (each post has 10-15 tags)
My wordpress site has more than 200k tags and it runs smooth, both blog and API.
I need to make use of {{get}} helper and API for my use but the tags API is justf ailing on me
