Ghost v3 crashes with a 502 on page load
  • What’s your URL? This is the easiest way for others to debug your issue
    [redacted after fix]
    3.1.1
  • What configuration?
    Installed using ghost-cli, running behind cloudflare and nginx
  • What browser?
    Chrome
ghost log [redacted after fix]
+ sudo systemctl is-active ghost_blog[redacted after fix]
[2019-12-07 11:47:46] INFO Bootstrap client was closed.
[2019-12-07 11:48:01] INFO "GET /" 200 797ms
[2019-12-07 11:48:02] INFO "GET /assets/built/screen.css?v=79770a5fe5" 200 27ms
[2019-12-07 11:48:02] INFO "GET /assets/built/casper.js?v=79770a5fe5" 200 6ms
[2019-12-07 11:48:07] INFO Ghost is running in production...
[2019-12-07 11:48:07] INFO Your site is now available on [redacted after fix]
[2019-12-07 11:48:07] INFO Ctrl+C to shut down
[2019-12-07 11:48:07] INFO Ghost boot 4.262s
[2019-12-07 11:48:47] INFO "GET /" 200 991ms
[2019-12-07 11:48:48] INFO "GET /" 200 281ms
[2019-12-07 11:48:54] INFO Ghost is running in production...
[2019-12-07 11:48:54] INFO Your site is now available on [redacted after fix]
[2019-12-07 11:48:54] INFO Ctrl+C to shut down
[2019-12-07 11:48:54] INFO Ghost boot 4.24s
[2019-12-07 11:49:00] INFO "GET /" 200 863ms
[2019-12-07 11:49:01] INFO "GET /assets/built/screen.css?v=03365b71ef" 200 21ms
[2019-12-07 11:49:07] INFO Ghost is running in production...
[2019-12-07 11:49:07] INFO Your site is now available on [redacted after fix]
[2019-12-07 11:49:07] INFO Ctrl+C to shut down
[2019-12-07 11:49:07] INFO Ghost boot 4.622s
ghost log blog[redacted after fix]
[2019-12-07 11:49:17] INFO "GET /favicon.ico" 302 17ms
[2019-12-07 11:49:19] INFO "GET /" 200 932ms
[2019-12-07 11:49:19] INFO "GET /assets/built/screen.css?v=fa02929a98" 200 11ms
[2019-12-07 11:49:20] INFO "GET /assets/built/casper.js?v=fa02929a98" 200 5ms
  1. Load the page
  2. See it crash and give 502 errors
I recently upgraded from v2 to v3 as I wanted to use the new features. With this, I had to update my node version which I did using the n package from npm. The upgrade worked fine, but now whenever I load the front page, it just crashes and gives me 502 errors.
How do I go about fixing this?
I’ve managed to resolve the issue by manually creating and moving all my images into the size/w1000/* folder.
I got the same issue (After upgrade from Ghost 3.0.3 to 3.1.1
  1. Nginx 502.
  2. Image link break.
I am just too lazy to deal with this.
How to rollback (from 3.1.1 back to 3.0.3)
ghost update --rollback
