I cant install ghost. terminal shows “Ghost was able to start, but errored during boot with Knex: run” copy of terminal commands is attached below.
Hosting - Shared Hosting | Steller package. Namecheap hosting
(Terminal Command )
[modknack@server123 ~]$ cd blog
[modknack@server123 blog]$ ls
current public stderr.log tmp
[modknack@server123 blog]$ source /home/modknack/nodevenv/blog/14/bin/activate && cd /home/modknack/blog
[blog (14)] [modknack@server123 blog]$ ls
[blog (14)] [modknack@server123 blog]$ rm -rf *
[blog (14)] [modknack@server123 blog]$ npm install ghost-cli@latest -g
ln: creating symbolic link /home/modknack/nodevenv/blog/14/lib/package.json': No such file or directory npm WARN lifecycle The node binary used for scripts is /home/modknack/nodevenv/blog/14/bin/node but npm is using /opt/alt/alt-nodejs14/root/usr/bin/node itself. Use the –scripts-prepend-node-path` option to include the path for the node binary npm was executed with.
yarn@1.22.19 preinstall /home/modknack/nodevenv/blog/14/lib/lib/node_modules/ghost-cli/node_modules/yarn
:; (node ./preinstall.js > /dev/null 2>&1 || true)
/home/modknack/nodevenv/blog/14/lib/bin/ghost → /home/modknack/nodevenv/blog/14/lib/lib/node_modules/ghost-cli/bin/ghost
- ghost-cli@1.21.1
added 478 packages from 270 contributors in 25.454s
node_modules
[blog (14)] [modknack@server123 blog]$ ghost install local
Love open source? We’re hiring Node.js Engineers to work on Ghost full-time.
https://careers.ghost.org/product-engineer-node-js
Checking system Node.js version - found v14.18.3
Checking memory availability
Checking free space
Checking for latest Ghost version
Setting up install directory
Downloading and installing Ghost v5.8.3
Finishing install process
Configuring Ghost
Setting up instance
Starting Ghost
One or more errors occurred.
- GhostError
Message: Ghost was able to start, but errored during boot with: Knex: run
$ npm install sqlite3 --save
/usr/lib64/libstdc++.so.6: version `CXXABI_1.3.8’ not found (required by /home/modknack/blog/versions/5.8.3/node_modules/sqlite3/lib/binding/napi-v6-linux-glibc-x64/node_sqlite3.node)
OS: unknown, vunknown
Node Version: v14.18.3
Ghost Version: 5.8.3
Ghost-CLI Version: 1.21.1
Environment: development
Command: ‘ghost install local’
Additional log info available in: /home/modknack/.ghost/logs/ghost-cli-debug-2022-08-10T07_32_01_262Z.log
