Has anybody else experienced constant per day reliability issues with google cloud ompute engine free tier builds of ghost. I have now twice built google cloud fee tier ghost installations to standard install instructions. Latest ghost version, latest compliant node, ubuntu etc. Absolutely vanilla builds per ghost install instructions.
Everything works, but roughly every 24 hours the compute engine errors out on http requests and i need to reset it. It does not go fallback to an nginx bad gateway issues, the compute engine is just toast.
I initially decided to use an instance schedule to recycle the compute engine every 24 hours. After all it is actually a bit of a joke to suggest a single core and 1gb of memory and networked disk is not going to be problematic running in any kind of contention environment. I initially assumed it was either contention or google faulting long running free tier compute engines.
However, even with the daily reset i am getting intermittent compute engine failures.
Any ideas for how to troubleshoot or similar experiences would be greatly apprecaited.
