Guidepost theme Search URL Wrong
Hello i am trying to get my search function to work using GuidePost, however whenever I try to do a search, the url it is trying to access is incorrect it is missing it’s pathing
However my posts are located at staging.kweeder.com /help
Do you know if there is a way to fix this in the theme?
*Update, managed to fix these creating a var ghost_root_url in the scripts.js allowing me to inject the url into ghosthunt.js in order to add the variant needed to access my page
Solution for reference:
