Hello,
I would get the search working on my Blog. Recently switch from Wordpress to Ghost. I followed this Guide on GitHub , also tried an HountedTheme in my Blog https://dasnetzundich.de but get no search results. What is wrong and can anyone help me?
Best regards
Lars
Looks like a configuration is missing. I would recommend checking the theme docs for theme configs.
Okay i look tomorrow what is Missing.
Okay, I have added this to the footer of a new Page. But nothing is showing when i open the Page.
mskian
December 2, 2019, 11:51am
6
Create a New page Named as Search
add this Below code on HTML Block
<input id="my-custom-input" type="text">
<div id="my-custom-results"></div>
Okay. I made it in this Site. But no search result.
https://dasnetzundich.de/suche/
mskian
December 4, 2019, 3:31am
8
seems you are adding the search SDK two times
remove it and check it will work
Okay, I removed the Code from the Theme. Used this tutorial before. https://github.com/HauntedThemes/ghost-search now the code is only at the Search Site.
Error: GhostContentAPI Config Invalid: @tryghost /content-api does not support the supplied version index.js:23:14
t index.js:23
t index.js:16
value ghost-search.min.js:9
