Hey everyone, I’m having an issue where header card images are displaying alongside the text content in a split layout instead of as background images. The cards have the correct structure with a <picture> element as a direct child of the .kg-header-card, but Ghost’s CSS seems to be forcing a flex layout that puts the image and content side by side.
The Problem
When I inspect the rendered HTML, header cards look like this:
<div class="kg-card kg-header-card kg-v2 kg-width-full">
<picture>
<img src="https://example.com/image.jpg" class="kg-header-card-image">
</picture>
<div class="kg-header-card-content">
<h2 class="kg-header-card-heading">My Heading</h2>
<h3 class="kg-header-card-subheading">My Subheading</h3>
<a href="#" class="kg-header-card-button">Button Text</a>
</div>
</div>
The structure looks correct (picture is a direct child of the card, not inside the content div), but the rendered result shows the image and text side by side in a split layout, rather than the image as a background behind the text.
What I’ve Tried
Removed
kg-layout-splitclass - This class was present and I removed it, but the side-by-side layout persists. -
Tried
data-kg-background-imageattribute - Switched to using Ghost’s native background image attribute, removed the picture element. Result: Full width card but no background image at all. -
Added CSS to override flex layout - Tried forcing
display: blockandflex-direction: unsetwith!important:
.kg-header-card {
display: block !important;
flex-direction: unset !important;
Still showing side by side.
Wrapped in container div - Following the approach from spectralwebservices, wrapped cards in a container div and targeted with CSS. No change.
Positioned picture absolutely - Tried making the picture element
position: absolutewithz-index: 0and content atz-index: 1. Ghost’s flex layout still overrides it.
What I’m Seeing in the Inspector
When I inspect the rendered page:
- The card has
display: flexapplied (fromcards.muin.css) - The picture element and content div are flex children, causing the side-by-side layout
- Even with
!importantflags, I can’t seem to override Ghost’s flex layout - The
kg-layout-splitclass is removed, but the split behavior persists
Questions
Is there a specific class or attribute that tells Ghost to render header cards with background images vs split layout? The docs mention
kg-style-image- does that need to be present? -
How does Ghost’s default CSS determine whether to show an image as background vs side-by-side? Is it based on the presence of
data-kg-background-image, or something else? -
Are there theme-specific CSS rules I should be aware of? I’m using a custom theme - could it be overriding the default header card behavior?
Has anyone successfully overridden Ghost’s flex layout for header cards to force background image display? What CSS specificity was needed?
The structure matches what I see in the Ghost docs, but the rendering doesn’t. Any insights would be super helpful!
Thanks,
Nic
