[Headline] Member only post doesn’t show excerpt on homepage - but the excerpt is showed on the post page
Would be ideal to show on the homepage to encourage click through
Can you explain a bit more?
Did you find a solution to this? Same problem, running Casper theme with latest version.
Members-only post excerpt is shown on the post page (which is appropriately locked behind the subscribe button) but not on homepage or index.
The code looks like it should call the excerpt:
{{#if excerpt}}
But it doesn’t. Full code for the post-card below:
<a class="post-card-content-link" href="{{url}}">
<header class="post-card-header">
<div class="post-card-tags">
{{#primary_tag}}
<span class="post-card-primary-tag">{{name}}</span>
{{/primary_tag}}
{{#if featured}}
<span class="post-card-featured">{{> "icons/fire"}} Featured</span>
{{/if}}
</div>
<h2 class="post-card-title">
{{#unless access}}
{{^has visibility="public"}}
{{#unless feature_image}}
{{> "icons/lock"}}
{{/unless}}
{{/has}}
{{/unless}}
{{title}}
</h2>
</header>
{{#if excerpt}}
<div class="post-card-excerpt">{{excerpt}}</div>
{{/if}}
</a>
<footer class="post-card-meta">
<time class="post-card-meta-date" datetime="{{date format="YYYY-MM-DD"}}">{{date}}</time>
{{#if reading_time}}
<span class="post-card-meta-length">{{reading_time}}</span>
{{/if}}
{{#if @site.comments_enabled}}
{{comment_count}}
{{/if}}
</footer>
</div>
