I was trying to add a toggle block by typing /t but accidentally hit return after the t, and was surprised to find it accepted the command and revealed an interface for adding a GIF from Tenor.com. I checked the card menu (that pops up when you type /) and there’s nothing listed for Tenor. I played around and found that /gif works the same way.
Are there other hidden cards available? Is there a plan to add Tenor to the list in the menu?
Weird! I should have included a screenshot. I don’t see GIF on mine (but clearly it still works if I type /gif or /tenor or just /t). Here’s what it looks like:
Aha. I’ll add that. It is confusing to be able to still get to the gif selector though, just by typing what seems to be a secret command. Is it possible to add it back to the menu, even without a defined key? Or, alternatively, don’t let /tenor or /gif work unless the key is defined?
There are other hidden cards. I accidentally stumbled over /com or /compare. You’ll get a card where you can add two pictures with a slider. Is there a full list of all available cards? I couldn’t find anything online.
