/gif might be bugging
when in a post you do /gif, it doesn’t display anymore.
CleanShot 2022-07-29 at 07.05.19
Setup information
Ghost Version
5.4
Node.js Version
v14.18.2
How did you install Ghost?
digital ocean
The message says, “…trouble reaching the Tenor API…”, which seems to be an API for delivering the GIF.
Can you explain how you are using this API?
hi @mjw,
i didn’t set up the Api it was set by ghost team here → GIFs in Ghost
Ah, I never used that. But I can confirm the same issue.
I note that the API has moved from V1 to V2, so this may be the issue.
