Fill out the following bug report template with as much detail as possible!
Are you sure this is a bug? If you just need help, post in the developer help category. If it’s a feature request, head to the ideas category.
Issue Summary
- Explain roughly what’s wrong
- What did you expect to happen?
When running Ghost via Docker, it runs a constant Node process that repeatedly kills my CPU and leaves my site hanging occasionally. Removing the container successfully removes the process.
Steps to Reproduce
- This is the first step…
- This is the second step, etc.
Setup information
Ghost Version
Share which version of Ghost you’re using.
Latest
Node.js Version
If self-hosting - share which version of Node.js you’re using.
v18.19.0
How did you install Ghost?
Provide some details about your install of Ghost if you are self-hosting.
docker compose
Include further details about your hosting and OS.
Debian
Database type
MySQL 5.7 / MySQL 8 / SQLite 3 / Other
MySQL 8
Browser & OS version
Include if reporting frontend bugs.
Relevant log / error output
Copy and paste any relevant log output. Use backticks to format this into code.
