Homepage customization kyiv (v2.7.1) theme question
Hello,
I did not find how to customize my Kyiv theme homepage to create a new section just under Hero subtitle with 3 columns (see image copied below) to insert some pages with content I created inside these columns. Do I need to insert some special code in the customization panel of the Design Theme or in the Pages customization? Thanks in advance for your precious guidance and help!
Hey!
The Kyiv theme is a Magic Pages exclusive theme, so not something that’s widely used here in the forum.
I’ve also just replied to your email, but in case somebody finds this here and has the same question:
Based on the screenshot it looks like you’re showing us the “features” section of the Kyiv theme. In that case, adding more pages tagged with #features will render them below.
Since the theme is a static collection of defined sections, there is no way of adding an entire separate section with heading etc. below though. For that, you’d need to edit the theme code itself.
Thank you for your answer. Is the number of ‘features’ limited to 5 or can I add 6 ‘ #features ‘ ?
It is not limited at all. You could technically also add 100 :slight_smile:
Great! So if I added ‘ #features ‘ in 6 of my ‘Pages’, the 6 of them shoud technically appear. I have only 5 appearing (see image below). The 6th missing has the hashtag so is there another thing I need to do to help the last one appear and how can I change the order in which they appear? Thanks
I’ll send you an email − will need to see the live site to help with this properly :slight_smile:
