I’m currently having Siri read the page after it’s created, record her voice, and then upload the audio file to the blog and play it that way.
Is there anything that does it on the fly and sounds natural?
hi, i use natural readers
i pasted the code in the “code injection” and it add a little widget that can read the page.
the free plan is generous: https://www.naturalreaders.com/
if you want to see it in action look at thestackjunction.com (my blog)
look into the bottom left corner here it says “listen”
Cool! I’ll check it out! Thanks!
Great. I have applied the information and it greatly worked
ohhh thanks Tiago! I was looking for this too :D
Thanks for the information
Thank you, works for me too.
just note that on some computers, like Mac you have by default and do this command:
say "your text here"
