With certain articles I would like to add a little warning banner like this:
Is there an easy way of doing this? I haven’t been able to create something like this.
Where do you want it? In the header or inline as in the post?
I would like this inline within the post, at the points where required.
You could create a simple HTML card and save that as a snippet for later re-use.
Here’s a basic example:
<div class="alert">
<span class="closebtn" onclick="this.parentElement.style.display='none';">×</span>
<strong>Warning!</strong> Your text here.
</div>
Then some CSS to make it look okay:
.alert {
padding: 20px;
background-color: #f44336;
color: white;
.closebtn {
margin-left: 15px;
color: white;
font-weight: bold;
float: right;
font-size: 22px;
line-height: 20px;
cursor: pointer;
transition: 0.3s;
.closebtn:hover {
color: black;
Thanks, that did help to get me started. Have got it like this:
Using the following template:
<div class="alert-warning">
<span class="alert" onclick="this.parentElement.style.display='none';">×</span>
<strong>Warning!</strong><br>It's not recommended to increase verbosity for daily use, as unbound logs a lot. But it might be helpful for debugging purposes.
</div>
With the following CSS:
.alert-warning {
border-style: none;
border-left-style: solid;
border-left-width: thick;
border-color: #f44336;
background-color: #f4c3c6;
padding-left: 4px;
border-radius: 15px;
padding: 20px;
color: black;
.alert {
margin-left: 15px;
color: black;
font-weight: bold;
float: right;
font-size: 22px;
line-height: 20px;
cursor: pointer;
transition: 0.3s;
.alert:hover {
color: white;
Nice. Happy I could help.
