How can I integrate multi-language feature in my Ghost blog?
I am trying to integrate multi-language feature in my existing Ghost blog but I don’t see anything working there. My blog works as a this URL format: domain.com/insight/. I already tried the procedure from this url: https://ghost.org/tutorials/multi-language-content/.
After doing the process as said in the tutorial when I open url eg. domain/insight/de/ then my home page content don’t show. Also when try to open post for de language(domain.com/insight/de/post-url) it redirects me to the main post url.
  • Ghost blog version 3.2.
  • I am using Casper theme.
I appreciate any help to make it work. Thanks in advance.
The routes.yml procedure does not filter pages, even though it says so in the url :sweat_smile:
Ghost is also missing other multi-language features, such as linking between same content but different language, and multilang navigation.
I hacked these with javascript; in settings > code injection > ghost_head I have a sitemap which needs manual updating:
var sitemap = {
	index: {
		fi: "/",
		en: "/en/",
	uneton: {
		fi: "/uneton/",
		en: "/en/uneton/",
…and then I hack the navigation.
If you want /en/ or /de/ in page url, you need full manual routes:
routes:
  /en/docs/:
    template: post
    data:
      post: page.docs_en
Good luck :stuck_out_tongue_winking_eye:
Thank you for the quick response.
So I will need to route everything manually? I have tag pages also, it will also need to route manually for different languages? I want to integrate 13 languages, do you think it will be possible?
Uh-oh, in theory it is possible (to manually route multiple languages), but in practise Ghost is not ready for this :pensive:
You could add everything as a post, then automatic routes work as documented. Or we’ll wait and hope it gets fixed to work with pages, too :relaxed:
Thanks friend, I am leaving that as it is for now.
Hey all :wave:. We’ve just spent some time updating our tutorial on using Ghost in different languages and in multiple languages. Any feedback you have is welcome :raised_hands:
David,
how about saying some more on navigation in multi-language sites?
Thnx
Could you be more specific? Do you mean having translated navigational items in your site?
Yes, I would need to translate the navigational items, while retaining their equivalences … i.e. the translated Home acts like home.
Best way to manage that would be with custom templates and custom partials. You could create a nav-fr.hbs partial for example and list all your custom nav items in there.
Thanks David,
I’ll play around with that. It requires the translations to be hardcoded, but it’s simple.
There’s a 3rd party service called Pressbase.io that has multiple language support out of the box.
It’s a 3rd party SaaS built on the open source Ghost 3 software.
Here is a workaround to achieve that :
  1. Create a template file hello_world.hbs
  2. Update the routes.yaml file as follow
/hello-world/:
    template: hello_world # referencing hello_world.hbs
    data: page.hello-world # You should create a page from admin that have slug : hello-world
/en/hello-world/:
    data: page.hello-word-en # You should create a page from admin that have slug : hello-world-en
  1. Write the code of the page in your hello_world.hbs and you can display the content of the page by using the {{#post}}{{/post}} block
:hugs: Voila! You have your multi-language pages with same slug
