Ghost.org In Multi-Language
I’m new at Ghost.org and I’m trying to see how far I can go with it.
So basically I want to set up a blog with multi-language following this way:
example.ghost.org/en (English version of posts and theme)
example.ghost.org/ar (Arabic version of posts and theme)
Is there any way to do that because I couldn’t find how to do it? do I need to use different admin panels, or I can do within one?
Best bet is to use routing:
I thought using different, custom subdomains.
en.example.com
ar.example.com
but pointing as example.com/en, /ar
but the problem will be the cache, because the reader they need to change every time language :frowning:
and installed in both of them the same theme, and posting in different languages, but it will take long time to edit the same in all the admin panels :(
