I am using the DocuHub theme and began setting it up. I noticed the main menues are different tags:
After playing around for a bit, I noticed the tags in the side bar are alphabetical. So I added numbers in front to order the. Cool figured that out.
If I tag a post with a specific tag it then falls under that tag in left hand side menu. You can see above in the “2. Quick Start” tag I have two posts. Settings Overview and Main Screen Overview.
My problem is I can figure out how to order the post. They do not seem alphabetical. I either want them alphabetical so I can number them like the tags or just in order I write them. Right now it looks like reverse order…
