How to add Audio - And Static page with pages from Tags
Hi !
I need some help with to configure how i could add songs and albums to certain pages. Such as Discography, and is it possible to buy some code for this? Like HTML5 on Codecanyon? I need to add albums from artists on a full page, so tracklist + album cover can be visible.
See example: draft2
And for the second question, is it possible to make a “Interview” static page, and add all articles that includes a certain tag?
This would be so great if it’s possible, thank you.
You can already retrieve a list of all posts with a particular tag by viewing the tag archive page for that tag, e.g. yourdomain.com/tag/interviews outputs all the posts with the tag “interviews.” If you needed to create a page instead, you could create a custom page template and use the {{#get}} helper to retrieve the posts for a specific tag.
Thank you Sarah for such fast reply, i will try to arrange this so it works. How would you suggest the audio problem i have? Is it possible to buy codes from CodeCanyon (HTML5) and they work with Ghost? Or do you plan to have Audio upload in the future with this feature?
Best Regards.
Ghost does not support audio uploads, but you can embed audio files from any service into Ghost, such as soundcloud.com, for example. :blush:
Okey, yes i know it works with SoundCloud but i’d like to have some kind of upload. Or using some third party application to make it look like the image i posted above. Do you know if this is possible?
(Does it have to be embedded)?
