How to center text?
How can I center text in this post?
I expected to see an option in the formatting bar the appears when the text is highlighted. It’s not there though.
Thanks!
P.S. - I searched forum for “center text” and didn’t find an answer.
Hey there!
In my opinion, you have multiple options to center your text, depending on what you’d like to achieve:
  1. When all your posts should always be centred: that should be solved on a theme level by adjusting the CSS for your theme → Ghost Handlebars Themes - Building a custom Ghost theme - Docs
  2. If this is a one-off thing: either use codeinjection for the post to overwrite/adjust the existing CSS (article {text-align: center;} for example), or use HTML card in the editor, where you can add inline style for the paragraphs you’d like to have centred (<div style="text-align:center;">I have a text here and it needs to be centred!</div>)
Hope that helps!
