How to configure ghost admin api with angular or postman
  • What’s your URL? This is the easiest way for others to debug your issue
    on a local I am using the ghost local install for test which is running on node version 10.x LTS and on the default ghost port on localhost
    the latest one
  • What configuration?
    I was able to generate the api key from backend even I was able to access the content api via postman, I want to access the ghost admin via postman what are the way to do that, as it require token for authentication that’s what I am able to understand.
  • What browser?
    chrome, postman
    Authentication Failed error
Also I am trying to integrate the ghost with my angular web
when I tried to add the client SDK I got the following error
index.js:43 Uncaught ReferenceError: global is not defined
at Object../node_modules/buffer/index.js (index.js:43)
at __webpack_require__ (bootstrap:78)
at Object../node_modules/safe-buffer/index.js (index.js:2)
at Object../node_modules/jws/lib/sign-stream.js (sign-stream.js:2)
at Object../node_modules/jws/index.js (index.js:2)
at Object../node_modules/jsonwebtoken/decode.js (decode.js:1)
./node_modules/buffer/index.js @ index.js:43
webpack_require @ bootstrap:78
./node_modules/safe-buffer/index.js @ index.js:2
./node_modules/jws/lib/sign-stream.js @ sign-stream.js:2
./node_modules/jws/index.js @ index.js:2
./node_modules/jsonwebtoken/decode.js @ decode.js:1
./node_modules/jsonwebtoken/index.js @ index.js:2
./src/app/app.component.ts @ main.js:127
./src/app/app.module.ts @ app.component.ts:11
./src/main.ts @ main.ts:1
0 @ main.ts:12
checkDeferredModules @ bootstrap:45
webpackJsonpCallback @ bootstrap:32
(anonymous) @ main.js:1
Hey @Vikas_Kandwal :wave:
The admin API is private so you shouldn’t be using a frontend (e.g. angular) to make requests to it. That’s why you’re running into the ReferenceError - the admin sdk is intentionally not compiled to work in the browser.
Have you seen these docs?
Postman supports importing requests from curl, so you can try that to see what you’re missing
If you’re trying to have a custom admin interface, I think your best bet is to use user authentication -
Instead of an integration doing lots of things, it becomes a user doing it
