Usually there are hundreds of popup plugins on the platform like wordpress but ghost does not have such a plugin unfortunately.
After researching, I found that this one is the best option for my case:
https://popupsmart.com (Free up to 10,000 page views)
But now I would like to know how to connect the sign up form to Ghost subscribers.
I would like to not use Zapier. Any ideas?
Hi! instead of a plugin, I will share how I manage to do this on my blog with code injection, I used this script:
The first part of the script is a function to find out if the visitor is logged in as a member or not, I decided to not show this pop up to already registered members.
The second part oppens the pop up, In my case I decided to show it once a day only, so it waits 86.400 seconds before showing it again (it stores this value in a cookie)
The third part is the trigger, it tries to open the pop up if visitor scrolled more than 25% of the page.
Here is the code:
<script>
// Define an async function to check if the current user is a member.
async function isMember() {
// Fetch the member status from the API and store the response.
const response = await fetch(`${location.origin}/members/api/member/`);
// Check if the response status is 200 (OK) indicating that the user is a member.
const bMember = response.status === 200 ? true : false;
// Return the member status.
return bMember;
// Define an async function to control the opening of a popup.
async function openPopup() {
// Check if the current user is a member.
const member = await isMember();
// Retrieve the timestamp of the last popup from sessionStorage.
const lastPopup = sessionStorage.getItem('POPUP_OPENED');
// Calculate the time passed since the last popup was opened.
const timeDelta = lastPopup ? (new Date() - new Date(lastPopup)) / 1000 : Infinity;
// Show popup once a day if the user is not a member.
if (!member && timeDelta > 86400) { // 86400 seconds in 24 hours
// Record the current time as the new 'last popup opened' time.
sessionStorage.setItem('POPUP_OPENED', new Date().toISOString());
// Create a temporary link element to trigger the popup.
const popupLink = document.createElement('a');
popupLink.href = '#/portal'; // Set the href to your popup's URL or anchor.
document.body.appendChild(popupLink); // Add the link to the body to make it clickable.
popupLink.click(); // Simulate a click on the link to open the popup.
document.body.removeChild(popupLink); // Remove the link from the body after opening the popup.
// Add an event listener for the scroll event on the window.
window.addEventListener("scroll", () => {
// Get the current scroll position.
let scrollTop = window.scrollY;
// Get the total height of the document.
let docHeight = document.body.offsetHeight;
// Get the height of the window.
let winHeight = window.innerHeight;
// Calculate the percentage of the page that has been scrolled.
let scrollPercent = scrollTop / (docHeight - winHeight);
let scrollPercentRounded = Math.round(scrollPercent * 100);
// Try to open the popup if the visitor has scrolled more than 25% of the page and is not a member.
if (scrollPercentRounded > 25) {
openPopup();
</script>
Use Make.com - free tier no cost, here’s the How-to
- PopupSmart Submit form, triggers…
- Ghost Create Subscriber
and thank you @jtraverso for the native js pop-up, creating a link an then clicking it is very elegant.
Brilliant, thank you so much for this
