I wanted t to know is there any forum theme or how can i create a forum website using ghost?
Like users can ask questions and other user can answer them.
You’d need to use some other software that’s specifically set up to work as a forum and then integrate that into your Ghost site.
Ghost itself doesn’t offer any functionality that would cover the needs of a forum.
Is there any tutorial that can help me?
You can try to integrate Flarum and Ghost both of them have api, with could help You.
Thank you so much, is there any way i can reach you?
or
or for more comments-like, less forum-like:
or
          Thanks bro. I will check it ang thanks for helping.
If you need: Serwer użytkownika deon._
Okay, i have joined. If i need help i will sure let you know.
