How to customize the "/tags" URL path for my tags overview page?
Hi, I’m building a blog that will include a Tags page, listing all the tags attached to my posts.
I’ve followed a tutorial based on the theme I’m using. One of the requirements in the tutorial is this one:
make sure that the page URL is “tags”
Now, this seems a bit rigid.
How do I customize this URL to e.g. “categories” or “themes”?
Ghost version: 2.0
This can be achieved with Dynamic Routing:
https://ghost.org/docs/api/v2/handlebars-themes/routing/taxonomies/#customising-taxonomies
Thnks, vikaspotluri123. Unfortunately, this is not exactly what I mean. I’m aware I can change the prefixes for “tag” or “author”. However, what I’d like to change is the path “tags” to something else, like “categories”. The “/tags” path currently serves an overview of all tags used on my blog. I simply need to change the URL of the page to something more descriptive.
And according to Ghost docs:
You can’t define new or custom taxonomies, you can only modify those which are already there
The only ones that are there are these:
taxonomies:
  tag: /tag/{slug}/
  author: /author/{slug}/
Aaah, I see what you’re doing…
What you would need to do is change the slug of the page to categories,
and then update the template name to page-categories.hbs
The method described in the tutorial still works, but I would suggest you use dynamic routing for this, since it’s capable of doing the same thing, but it’s more maintainable. You would just need to create the route (e.g. /categories) and specify the template to use in the definition
Yeeep. Works. Thank you!
