How to disable infinite scrolling with Casper theme
How to disable infinite scrolling with Casper theme 3.0.2?
Thanks for helping.
:pensive:
I also have the same question, is there a quick way to disable infinite scroll in the latest Casper version?
Bump! Looks like some custom JavaScript has to be removed in assets/ I’ll post back if I figure it out.
I like to know this as well, it is causing issues on the homepage when you use the {{#get}} command to filter the post by category, on scroll casper proceeds to load everything. Very annoying.
