This question is a self-answe . Writing this for updating the community’s collective knowledge.
If a user wants to add React component to their existing Ghost template without creating new react app, how can they add that?
To integrate React with Ghost you will need the following -
Prior knowledge of webpack and babel is important. You can learn what is required within a day.
Once you feel you are comfortable with Babel and Webpack, follow the link - Integrating webpack into the Casper theme (Ghost) | by Vu Tran | Medium
I will be adding code later.
Hi there,
I would appreciate it very much if you add code and more knowledge resources here. Thank you!
Hi, I got tied up with other stuff. Let me look at my old code and see if I can find it.
Gentle reminder. Its been an year I hope you have the code now. Please share it.
Thanks
It seems that there are still people who are waiting for a solution to this. For my use case, I have integrated React into the (previously default) Casper theme. I have forked it and here is the repository.
To get into the specifics, I have a Webpack config that builds from the src directory as is standard in React apps. After that, I load the compiled JS file into the bottom of the default.hbs file, this is what my default.hbs file looks like. This line specifically loads everything:
<script src="{{asset "built/main.bundle.js"}}"></script>
Feel free to inspect my repo if anyone has questions!
