I want to use some libraries that based on ES6 so how can i used them in Ghost.
@Adil_Osama_Rasheed your question is missing sufficient context for anyone to give you an answer.
Where are you trying to use the libraries - In your front-end theme code? in core? in a headless app that’s using the Content API?
If you’re trying to use them in your theme then there is nothing Ghost-specific for that use-case. You would need to use babel and a bundler like webpack in the same way as you would in any other front-end project, you should be able to find some good generic guides/tutorials on that via Google.
Thanks
