Hello everybody!
Before I represent my problem I would like to give you some background:
Ghost currently hasn’t got an opportunuty to make multilanguage blogs. The blog’s language can only be changed static through the Ghost Admin panel.
As I need a fully multilanguage resource (I want my blog to have an opportunuty to change language on client side), I made my own helper that makes this possible.
Everythings quiet okay, BUT when I`m updating Ghost core or disactivate my theme, every time I try to activate it again Ghost throws me errors connected with my custom helper. the solution I use is commenting lines with this helper out in my theme before applying it to my blog.
I wonder if :
Is there an opportunity to skip this step with theme validating?
Or some way to launch theme without commenting lines with custom helpers?
Can theme get activated without validation?
This is totally unconvinient, because if I would give my theme to somebody else, it definetly won’t work out, before I teach him/her how to comment out all lines with my helper. But what if the person isn`t a programmer and can’t edit code?
Thanks in advance for your ideas. ![]()
