Hi there,
I have been following your documentation on uploading posts via the javascript client library. I have gotten the HTML example to work, but I am wondering if it is possible to upload markdown?
I have some markdown articles that I would like to upload and I do not want to first convert them to HTML. Any advice is appreciated!
Thanks
Is the issue is that you don’t want to do the conversion or that it’s important to you to keep the content in Markdown?
I didn’t want to do the conversion, but it looks like maybe that is easy to do with showdown. I am trying to make an importer to Ghost from Gdocs using Apps scripts for my team to use - copy and pasting doesn’t format e.g. inline code so we have to go back and delete a backtick and then re enter it for the Ghost editor to format it as code.
