How to use cdn with ghost?
Hello everyone i want to use a cdn with my ghost blog so all images and static files will be served through that cdn.
But i didn’t found a way to do so.
So please help me.
Thanks
Are you using CloudFlare or is this a DIY CDN?
Hey, did you check out this page? https://docs.ghost.org/docs/using-a-custom-storage-module
This might help :slight_smile:
A google search shows you:
https://help.ghost.org/article/8-root-domain-setup-using-cloudflare
Cheers!
Hello everyone i have already setup cloudflare with my ghost blog and it is working fine.
This topic can be closed
If anyone is looking for CDN alternatives then KeyCDN has provided a helpful guide on using Ghost on their platform:
