This is the yaml I use to deploy ghost on Kubernetes using the helm chart from https://charts.bitnami.com/bitnami.
affinity: {}
allowEmptyPassword: false
args: []
automountServiceAccountToken: false
clusterDomain: cluster.local
command: []
commonAnnotations: {}
commonLabels: {}
containerPorts:
http: 2368
https: 2368
containerSecurityContext:
allowPrivilegeEscalation: false
capabilities:
drop:
- ALL
enabled: true
privileged: false
readOnlyRootFilesystem: true
runAsGroup: 1001
runAsNonRoot: true
runAsUser: 1001
seLinuxOptions: {}
seccompProfile:
type: RuntimeDefault
customLivenessProbe: {}
customReadinessProbe: {}
diagnosticMode:
args:
- infinity
command:
- sleep
enabled: false
existingSecret: ''
externalDatabase:
database: ghost
existingSecret: ''
host: mariadb01.example.com
password: SomeSecret
port: 3306
ssl: false
sslCaFile: ''
user: ghost
extraContainerPorts: []
extraDeploy: []
extraEnvVars: []
extraEnvVarsCM: ''
extraEnvVarsSecret: ''
extraVolumeMounts: []
extraVolumes: []
fullnameOverride: ''
ghostBlogTitle: Blog of René Jochum
ghostEmail: ghost@example.com
ghostEnableHttps: true
ghostHost: example.com
ghostPassword: anotherSecret
ghostPath: /
ghostSkipInstall: true
ghostUsername: jochumdev
global:
compatibility:
openshift:
adaptSecurityContext: auto
imagePullSecrets: []
imageRegistry: ''
storageClass: ''
cattle:
systemProjectId: p-g2j9j
hostAliases: []
image:
debug: false
digest: ''
pullPolicy: IfNotPresent
pullSecrets: []
registry: docker.io
repository: bitnami/ghost
tag: 5.82.2-debian-12-r0
ingress:
annotations: {}
apiVersion: ''
enabled: false
extraHosts: []
extraPaths: []
extraRules: []
extraTls: []
hostname: rene.example.com
ingressClassName: ''
path: /
pathType: ImplementationSpecific
secrets: []
selfSigned: false
tls: false
initContainers: []
kubeVersion: ''
lifecycleHooks: {}
livenessProbe:
enabled: true
failureThreshold: 6
initialDelaySeconds: 120
periodSeconds: 10
successThreshold: 1
timeoutSeconds: 5
mysql:
architecture: standalone
auth:
database: ghost
existingSecret: ''
password: ''
rootPassword: ''
username: bn_ghost
enabled: false
primary:
persistence:
accessModes:
- ReadWriteOnce
enabled: true
storageClass: ''
resources: {}
resourcesPreset: small
nameOverride: ''
networkPolicy:
allowExternal: true
allowExternalEgress: true
enabled: true
extraEgress: []
extraIngress: []
ingressNSMatchLabels: {}
ingressNSPodMatchLabels: {}
nodeAffinityPreset:
key: ''
type: ''
values: []
nodeSelector: {}
persistence:
accessModes:
- ReadWriteOnce
annotations: {}
enabled: true
existingClaim: ''
storageClass: ''
subPath: ''
podAffinityPreset: ''
podAnnotations: {}
podAntiAffinityPreset: soft
podLabels: {}
podSecurityContext:
enabled: true
fsGroup: 1001
fsGroupChangePolicy: Always
supplementalGroups: []
sysctls: []
priorityClassName: ''
readinessProbe:
enabled: true
failureThreshold: 6
initialDelaySeconds: 30
periodSeconds: 5
successThreshold: 1
timeoutSeconds: 3
replicaCount: 1
resources: {}
resourcesPreset: micro
schedulerName: ''
service:
annotations: {}
clusterIP: ''
externalTrafficPolicy: Cluster
extraPorts: []
loadBalancerIP: ''
loadBalancerSourceRanges: []
nodePorts:
http: ''
https: ''
ports:
http: 80
https: 443
sessionAffinity: None
sessionAffinityConfig: {}
type: ClusterIP
serviceAccount:
annotations: {}
create: true
sidecars: []
smtpExistingSecret: ''
smtpHost: mail.example.com
smtpPassword: thirdSecret
smtpPort: '587'
smtpProtocol: tls
smtpService: ''
smtpUser: ghost@example.com
startupProbe:
enabled: false
failureThreshold: 6
periodSeconds: 10
successThreshold: 1
timeoutSeconds: 5
tolerations: []
topologySpreadConstraints: []
updateStrategy:
type: RollingUpdate
volumePermissions:
enabled: false
image:
digest: ''
pullSecrets: []
registry: docker.io
repository: bitnami/os-shell
tag: 12-debian-12-r18
resources: {}
resourcesPreset: none
securityContext:
runAsUser: 0
seLinuxOptions: null
As I’m using rancher it’s a thing of some clicks to install a new instance of ghost for me else you can use.
helm repo add bitnami https://charts.bitnami.com/bitnami
helm repo update
helm install -n blogs ghost1 bitnami/ghost -f values.yaml
To deploy with Traefik as Ingress:
apiVersion: traefik.containo.us/v1alpha1
kind: Middleware
metadata:
namespace: blogs
spec:
ipWhiteList:
sourceRange:
- 10.0.0.0/8
kind: IngressRoute
metadata:
namespace: blogs
spec:
entryPoints:
- websecure
routes:
- kind: Rule
match: Host(`blog.example.com`)
priority: 10
services:
- kind: Service
passHostHeader: true
port: https
scheme: http
- kind: Rule
match: Host(`blog.example.com`) && PathPrefix(`/ghost/api/admin`)
middlewares:
- name: ghost-admin
priority: 20
services:
- kind: Service
scheme: http
tls:
certResolver: letsencrypt-prod
