Https site url and redirect loop
When I change the URL of my blog to https:// i get
… redirected you too many times.
Try clearing your cookies.
My nginx config:
server {
    server_name ....;
	listen .;
    return 301 https://_$request_uri;
server {
    listen .:443 ssl;
	server_name .....;
	ssl_certificate .....
    ssl_certificate_key .....
	 location / {
        proxy_set_header HOST $http_host;
        proxy_set_header X-NginX-Proxy true;
        proxy_pass http://127.0.0.1:2369;
        proxy_redirect off;
I cant understand how fix it :worried:
I need this for change sitemap url.
@enoter you’re missing headers that are required for Ghost to work, the X-Forwarded-Proto one is especially important for SSL. You can see the template Ghost-CLI uses for the full list of required headers.
I would suggest using Ghost-CLI if possible.
Thanks for your help :relaxed:
